Hello
I've been working on Solidworks Composer for a short time and I'm having a problem with the resolution of circles as you can see in the following image. How do you get a perfectly round circle?
Thank you in advance for your answers
Hello
The circle is not round at the moment, it's a performance gain, but once your document is generated, your circle will be round:)
What do you call generating the document?
The circle has facets, but it is only a graphical representation to save memory resources.
To make your circle perfect
"What do you call generating the document?"
for example the documents you are going to print.
At the bottom of your page in option
You have quality with a bar that is more on high than on low. Grow up again and you'll see your circle grow. Otherwise, as said@MaD when you open the room, it will be perfectly round. generate=click on Calculation!! :)
Cdt
Changing the quality slider (and then pressing the calculation button) doesn't change anything
Yes, the SA is useless because it is only an overview that does not update.
When you save your file and open it with another software, you won't see all these facets!
If I save my file whether it's in vector (.svg open with illustrator) or in png (open with all software capable of opening a png) it doesn't change anything, I still have these edges
Have you also tried to increase pixels and dpi??? If you increase it in theory it should increase the quality (and the size of the file...)
Cdt
