Hello
could someone help me create this spring with CATIA V5 : http://cjoint.com/?DHjuKXwjG88
Thank you
Hello
Thank you
Hello
Tests here.
http://youtu.be/NIv-Rz7Yacg
Good luck.
Hello.
Want to learn how to create it? Because there are some made of everything (Traceparts).
See tab on the site.
Which version of catia do you work with?
What should this file do (represent a single spring or be configurable to generate a family of parts)?
Hello, I watched the tutorial on Youtube.
It's a good start except that to draw the circle that we're going to sweep on the spline.
A normal plane must be created to the propeller by one of the vertices of the propeller.
and create the circle on this plane.
Hello.
For the first attachment:
Tjrs in the surface workshop.
We create the open circle, we create a straight line tangent to this circle with the low point of the helix as the endpoint.
Then a connecting curve must be created between this line and the propeller to ensure the continuity of the guide for the sweep.
After rest + that to cut and assemble all this to make a single "guide" entity depending on the modules installed there is a cut/assembled function that does it in one go, otherwise you have to cut first and then assemble.
For the Top buckle.
Same scenario except that before you have to plan the cutting point of the propeller which determines the orientation of the fastener in relation to the first one (in your case parallel)
The first attaches to the attached file.
A big thank you to you Franck, that's exactly what I wanted to do!
Hello
OK, here's the creation of the bass loop in video.
Coffee break and then I post the rest.
