Hello
I have a problem with the combination of view cropping and view of another position.
Everyone knows the view cropping, for the view of another position, it allows you to put 2 (or more) configurations of a set on the same view. The configuration used for the basic view appears as a strong line, the other configurations appear as thin mixed lines.
Personally I have 2 uses: either to make the different positions of a mechanism appear, or to make an environment appear.
My problem is that cropping works well on the base view but not on views from another position.
It seems to work for me (SW2018 SP5)
Image before cropping:
After trimming:
The dotted view is well cropped too.
Can be a version option or bug.
it doesn't help me much ;-)
On this project, I'm with SW2017SP5 but I remember having the problem with other older versions. it may have been solved with the 2018 version...
Have you tried to make a ticket to the hotline, they will tell you if it's a known bug or not or if it's an option that is disabled.
Because like that I looked, but no option that in my opinion could activate or not this feature, I'm leaning more towards a bug.
That's what I felt.
I'll try the ticket, given your 1st answer, I think I know their answer.
