I'm having a problem with my solidworks, when I select a part that is in a subassembly, the feature manager doesn't scroll down and doesn't identify the part to select. The feature manager remains blocked and displays only the subset.
Do you know how I can find the complete flow of the creation tree?
Hello; Be careful, the "rolling" of the feature manager has a lot of trouble if you have created subdirectories in your Tree. The "grouping" of similar components also disturbs him from time to time, the same if the selected component is part of a repetition...
(A small screenshot will help us with the "Diagnosis"...)
I guess you had imported a lower version profile? If this is the case or for some other reason, your profile is probably corrupted. (error in the registry). So he'll probably reset your profile to start over on a healthy basis.
