Hello
I'm still on my assembly setup, and I'm almost getting there. I'm missing a little element.
To finish my project, I open a drawing, and I ask him to position me with views of several rooms. So far you're fine, except that I come across a coin with 2 bodies, and I want to have a view of my first body unfolded, and a view of my second body.
Here is an example of my procedure for recovering views.
Set swModel = swApp.OpenDoc6("Z:\MACHINE\CONFO\0 confo ORIGINE 3D\Sheet metal confo ORIGINE.slddrw", 3, 0, "", longstatus, longwarnings)
Set Part = swApp.ActiveDoc
Set myModelView = Part.CreateDrawViewFromModelView2("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & " base.sldprt", "*Top", 0.33, 0.68, 0)
boolstatus = Part.ChangeRefConfigurationOfFlatPatternView("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & " base.sldprt", "Default")
Set myModelView = Part.CreateDrawViewFromModelView2("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & " wing.sldprt", "*Face", 0.33, 0.43, 0)
boolstatus = Part.ChangeRefConfigurationOfFlatPatternView("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & " wing.sldprt", "Default")
Set myModelView = Part.CreateDrawViewFromModelView2("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & " corridor.sldprt", "*Face", 0.33, 0.18, 0)
boolstatus = Part.ChangeRefConfigurationOfFlatPatternView("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & "corridor.sldprt", "Default")
Set myModelView = Part.CreateDrawViewFromModelView2("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & " corridor.sldprt", "*Face", 0.95, 0.68, 0)
'boolstatus = Part.ChangeRefConfigurationOfFlatPatternView("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & "corridor.sldprt", "Default")
Set myModelView = Part.CreateDrawViewFromModelView2("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & " base.sldprt reinforcement", "Unfolded state", 0.95, 0.43, 0)
boolstatus = Part.ChangeRefConfigurationOfFlatPatternView("Z:\MACHINE\CONFO\" & Range("d1"). Value2 & "base.sldprt reinforcement", "Default")
The room concerned is the one with corridor.sldprt.
Kind regards.
