Option Explicit
Sub main()
Dim swDraw As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swDispDim As SldWorks.DisplayDimension
Dim swDim As SldWorks.Dimension
Dim swDimTol As SldWorks.DimensionTolerance
'Dim swAnn As SldWorks.Annotation '
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then MsgBox "Veuillez ouvrir un dessin": Exit Sub
If swModel.GetType <> swDocumentTypes_e.swDocDRAWING Then MsgBox "Veuillez ouvrir un dessin": Exit Sub
Set swDraw = swModel
swModel.ClearSelection2 True
Set swView = swDraw.GetFirstView
While Not swView Is Nothing
Set swDispDim = swView.GetFirstDisplayDimension5
While Not swDispDim Is Nothing
If swDispDim.GetType = swDimensionType_e.swRadialDimension Or swDispDim.GetType = swDimensionType_e.swDiameterDimension Then
Set swDim = swDispDim.GetDimension2(0)
Set swDimTol = swDim.Tolerance
swDimTol.Type = swTolType_e.swTolFITWITHTOL
swDispDim.ShowTolParenthesis = True
' Set swAnn = swDispDim.GetAnnotation '
' swAnn.Select3 True, Nothing '
End If
Set swDispDim = swDispDim.GetNext5
Wend
Wend
Option Explicit
Sub main()
If swDispDim.GetType = swDimensionType_e.swDiameterDimension Then
If swDimTol.Type = swTolType_e.swTolFIT Or swDimTol.Type = swTolType_e.swTolFITWITHTOL Then
End If
End If
Wend
Wend
