Hello, I want to do a simulation with solidworks folw for a refrigerator, in order to see the thermal chrage and know the areas where the heat penetrates more, the only possibility I found is to impose a temperature on the outer wall to simulate the internal flow, but is it possible to give the outside temperature and not that of the wall?
Hello
Why wouldn't it be possible to choose the temperature of the fluid outside?
The external temperature of the fluid can be chosen from a selection:
Hello
Yes, this is possible by doing an external or not an internal study.
why don't you opt to do an exchanger-type study
you will have your outside temperature gas / fluid flow at x temperature at the inlet and x flow,
your walls, and your internal temperatures gas/fluid flow at x inlet temperature and x flow rate
you make a cut and you find the singular points via the color scale in the middle set
See this link Flow Echangeur tutorial
http://www.youtube.com/watch?v=8_KM8FUXQFo
