Hello
Dsl for the response time, I had to return my AVP!
I know about the deformation scale, I'm used to modifying it, often customers call me back in panic to ask me if it's the real scale, so I always end up putting captures at scale 1.
I was talking about creating a sldflp (sketch file for the welded construction) with the profile I'm interested in, but it doesn't seem to work, I don't understand why.
After creating the file, I use it to make a beam via the welded construction function, everything works:
Then, I mesh in beam element, we should see sections of mesh, but the model remains smooth I had never seen that before:
I launch the study, I have the following alert:
that I can't solve by rummaging through the menus indicated. Then I have this kind of vision on the trips:
(I have enabled beam rendering), and the constraint drawing does not work. I would like to find the solution to this problem because it is important for what I do.
After the volume I use it a lot when I have plates welded in all directions or for lifting equipment for example (spreader beam etc. that kind of thing) but on structures we spend 5 times the calculation time on volume compared to beam (taking into account the drawing of the model) because on a set of beams the junctions are made in 5 seconds, in volume we have to treat the fittings, put the plates, check for collisions...
If I have this problem again, I will try the support directly.
For my problem with the post, I did with folded sheets that I made integral with the connections menu, it worked. Thank you for your help in any case.
Have a nice day
