Hello
When requesting the use of the Compose Takeaway command, a message "sldshellutils " is displayed and disallows the
Hello
Hello
Look there:
http://www.lynkoa.org/forum/3d/n-pas-pu-charger-solidworks-dll-sldshellutils
Hello
If it's version 2015 SP4, please check if the Microsoft KB3072630 is installed from Windows Update, like this:
1. To open Windows Update, click the Start
button . In the search box, type Update, and then, in the list of results, click Windows Update.
2. In the left pane, click View Update History.
If so, you should uninstall it by following this tutorial:
http://www.mycadblog.fr/problemes-solidworks-rencontres-apres-la-mise-a-jour-de-microsoft/
If it doesn't work, you can reset the SolidWorks settings (which you can restore later) to determine if it comes from the configuration of the workstation: http://www.lynkoa.com/tutos/3d/reinitialiser-les-parametres-solidworks
I got the same message with SW2011.
What's your version?
