Hello
I would like to put my order number in the smartproperties of the assembly and automatically retrieve it in the smartproperties of the rooms.
Thanks in advance
Hello
Thanks in advance
Hello.
I don't see how it's possible: your parts can be used in 1,2,3,etc assemblies. So, your parts must take the order number of which assembly? The 1st? the 2nd? the tenth?
Hello;
SmartProperties allows you to achieve this type of recursion (Parent-child) via the " Property of referenced document" command:
But I strongly advise against its use: You will spend your time updating your documents at the slightest modification and the risks of errors are important... (although it is possible to automate this task with the " Integration " tool)
Kind regards.
Hello
I tried your solution but it doesn't work
Hello;
Uh... All right... But could you be a little more explicit, such as:
What is not working?
The ownership of the assembly does not go back down to your parts?
The ownership of the assembly goes down to your parts but not in all?
The property of the assembly goes down to your parts but is not correct?
other...
Feel free to take a few screenshots (screenshots, not photos) to illustrate your point.
By the way, what versions of Solidworks and MyCad utilities do you use?
