Hello;
@info.gascoin19 ... To what extent can we martyr these assemblages?
Basically, what do you want to keep in good condition and what are the less important components that can be " simplified " to the extreme?
Which version of Solidworks for the final version (if we can do it...)
excerpt from the C220866 Imerys left Side_step. STEP
Hello
I'm on solidworks 2024 SP2.
Ideally, the outer envelopes of each component should not be touched, I need to display the contents of the 2 steps in order to include them on the cross-sectional views of a building.
I attached a global screenshot of the project and a zoom on the 2 steps that are blocking me
Thanks in advance
So I can quietly remove all the internal components?
Question:
The WWTP:
Is there a complete symmetry of the step
C220866 Imerys right Side_step?
(and vice-versa)?
FYI: Just by removing only the internal components with the " Solidworks " selection: we gain about 8MB
and then Delete (keyboard).
The 2 steps are almost identical, but not symmetrical, a rack with cylinders is present on one of the steps.
Argh... Too bad for the symmetry.
I have just applied a " naughty " method: on the first assembly...:
Removed the internal components (see previous post) and then I simply deleted the bodies and faces in error...
See if you can do something with it (if it suits you).
C220866 Imerys left Side_(Without internal-method-Bourrin components). STEP (193.6 MB)
Hello
Thank you for this light stp, but the backup problem is still present.
I will try to " delete " each component one by one to identify the one that is blocking me.
Kind regards
Hello
My problem is solved, I had to resign myself to redrawing in a very simplified way the elements from the Step, in order to lighten the modeling.
Thank you for the help of the community.
