I would have liked to know if it was possible in a text (Dans une esquisse) to recover the value of a dimension?
Because currently the only way I've found is to go through a custom property that gives the value to the text and an equation and the equation then gives the value to the dimension. But it's really not practical.
I forgot to mention that it was in a 3D room (Not in a drawing!). And so when I insert a text into a sketch, I don't have access to the dimensions or the equation.
Save the piece and it's possible that the formula lost the link. If you go to configuration specific property (in my room) desigantion; it is there. Copy it and paste it back into the sketch and then it will work... otherwise it's
Ø"D1@Esquisse1@Tu Ø.sldprt"x"D5@Extru.-Mince1@Tu Ø.sldprt" Lg "D1@Extru.-Mince1@Tu Ø.sldprt"
And otherwise for your piece, when you create your sketch and put your text in it, you paste the text of your function side or you link it directly. If ever put your piece with what you want and I'll look ..
Have you tried a CTRL-Q to get it to find the link??? Otherwise I made you a 2nd piece where the text points directly to the specific properties of the configuration. you can do the same thing with your piece... After modifying the sides you must not forget to rebuild with the two-color light or CTRL-Q
Thank you, it works! Indeed it must have been a problem of reconstruction.
On the other hand, before I validate as a correct answer, do you know if it is possible to indicate a two-digit value? (For example, Ø76.10 instead of Ø76.1 or Ø76.00 instead of Ø76).
