I have to make a series of numbered plates cut with a laser I am looking for a solution to generate the DXF on solidworks automatically thank you in advance
Hello;
You should be able to perform your bulk exports with the " Solidworks Task Scheduler"
Otherwise I think there are already some macros lying around on the Forum...
For example, the macro of @js_1207
Transcript below:
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const MAX_PATH As Long = 260
Function BrowseFolder(Optional Caption As String, Optional InitialFolder As String) As String
Dim SH As Shell32.Shell
Dim F As Shell32.Folder
Set SH = New Shell32.Shell
Set F = SH.BrowseforFolder(0&, Caption, BIF_RETURNONLYFSDIRS, InitialFolder)
If Not F Is Nothing Then
If F = "Desktop" Then
BrowseFolder = Environ("USERPROFILE") & "\Desktop"
Else
BrowseFolder = F.Items.Item.Path
End Function
Dim swmodel As SldWorks.ModelDoc
Dim sFileName As String
Dim Path As String
Dim nErrors As Long
Dim nWarnings As Long
Dim PartNoDes As String
Dim stPath As String
Dim lgFichier As Long
Dim blretval As Boolean
' Set swExportPDFData = swApp.GetExportFileData(1)
Path = BrowseFolder("Select a Path/Folder")
If Path = "" Then
MsgBox "Please select the path and try again"
End
Else
Path = Path + "\"
sFileName = Dir(Path & "*.sldprt")
Do Until sFileName = ""
Set swmodel = swApp.OpenDoc6(Path + sFileName, swDocPART, swOpenDocOptions_Silent, "", nErrors, nWarnings)
Set swmodel = swApp.ActiveDoc
Set swPart = swApp.ActiveDoc
If swmodel.GetPathName = "" Then
MsgBox "Veuillez enregistrer votre document avant de lancer la macro", vbInformation
End
Else
'on récupére l'emplacement du fichier
stPath = swmodel.GetPathName
'on récupére le nombre de caractére jusqu'au . de l'extension
lgFichier = InStrRev(stPath, ".", -1, vbTextCompare) - 1
'on récupére le chemin sans l'extention
If lgFichier > 0 Then
stPath = Left(stPath, lgFichier)
'si le document est une pièce
If swmodel.GetType = swDocPART Then
'on créer le déplié
blretval = swmodel.ExportFlatPatternView(stPath & ".DXF", 1)
'on créer le DXF
blretval = swmodel.SaveAs3(stPath & ".DXF", 0, 0)
swApp.QuitDoc swPart.GetPathName
Set swPart = Nothing
Set swmodel = Nothing
sFileName = Dir
Loop
MsgBox "All Done"
End Su
Here is what I found from the archives:
By following Lynk's method for example:
Then to export via task scheduler cf method @Maclane or via macro or batchconverter (one month trial version downloadable)
And this one a little more detailed:
Or without SW:
MyCADtools link for the Batchconverter trial utility:
… Additional Response @sbadenis ![]()
I'll take care of the *.dxf and you will take care of the numbering then...?
