Overlay Notes and Dimensions in a SW Drawing
Hello
How to interrupt dimension attachment lines to avoid collisions with notes
(due to the clutter of the mEP, no other possibilities for the location of notes that are superimposed on dimension attachment lines)
Thanks in advance
Hello
It seems to me that it is impossible to cut a rib in relation to a note... Between the ribs it's possible but I haven't found for the notes...
It is possible to drag the dimension line so that it no longer crosses the note
When there is no more space, another drawing sheet is made
and it gives a better reading
or we change the format
It seems to me that in the rating properties you can ask them to be "above the dimensions" (at least, it works with the dimensions). Which is equivalent to the Words option of the same thing: putting yourself in the foreground and thus automatically cutting off harmful lines
Hello
Indeed you can interrupt a tie line that would cut another tie line at 90°, but nothing like it for a note or its d line which is superimposed on a side tie line (at least with my SW2014 SP03 version)
Impossible I think to put a white background to this note to hide the lines of attachment that cross?
I also didn't find the possibility of being "above the hills"
"it is possible to slide the sidecut so that it no longer crosses the note", I don't see how!
I do have a solution but unorthodox inserted a word document with a text box having a white background
CF Attachment
