SW : Angle de depouille
dear community,
I have designed this parts.
Capture1
Capture2
this parts have two claw for fix to a PCB (1.6mm). My aim is to add a tiny angle on each claw for to be sur that that this parts fit exactly to the pcb.
My pcb : 1.6mm
The claw : Start 1.65mm / End 1.55mm
for my the best function is to use the « clearance angle », but the result is not good.
do you an idea ?
Hello
Make a sketch and remove the material. Quick and easy for a not very complicated part
Suggested K.I.S.S. method
Hello Zozo_pm,
what’s K.I.S.S. method?
Thank for your answer.
AR.
This is kissing your computer and maybe it does what you want :rofl:
hello @A_R
Le principe est toujours de faire le plus simple possible.
Keep It Simple and Stupide
:crazy_face:
OK ok ok !!!
Merci pour ton message … ainsi je peux améliorer mon vocabulaire en UK…
bon après-midi,@+
AR.
