Hi all
Currently testing the "Structure System" module of solidworks, I realize that the structure I built is saved as a single part. Except it's a beam assembly (I and H), to which I would like to add a set of fixing plates.
I see that these so-called bolt fasteners do not exist in bookcases, and that the mechanically welded gusset tool leaves something to be desired.
Also I was wondering if it was possible to export each beam and columns separately in an assembly, while remaining editable (the option to export a saved body... a dead body).
Thank you all
