Hello, I made tapped holes in an assembly, but in the drawing it only appears the smooth hole without representation of the tapping...
If I import the " thread representation" annotations in the front view, it's good they appear, but they don't follow in the cross-sectional views, nor in the different views (right, left...)…
Can you help me???
You have to go through " Model object" and then check the box " thread representation " and select all the views concerned.
It has been common for many years on SolidWorks, thread representations do not automatically import to the drawing from an assembly.
OK, thank you very much...
That's when it works more or less normally...
Thread annotations are one of the most buggy/random functions of SW.
