Hi all
Someone could make a stamped sheet metal like this on SolidWorks 2014 or lower:
http://www.porte.fr/upload/887.jpg
I tried 5 min, but I don't use this tool often and it doesn't give me the result I want.
Hi all
Do you have any odds to give?
sheet metal and boss thickness between the axes of the bosses length width of sheets
A very good tutoiel here: http://www.lynkoa.com/tutos/3d/outil-de-forme.
Everything is clear!
If not, help http://help.solidworks.com/2012/French/SolidWorks/sldworks/c_Forming_Tools.htm
And a more generalist site here
diameter of your holes since your bosses are perforated
etc... full of misses to be able to help you
Hello
Have you tried with the sheet metal library functions of the "Bumps" type provided with the SW install? and then a repeat function. But you've probably thought about it!
Kind regards
... What better than Benoit... =)
+100
I don't know but Jmsavoyat has released another magic thing (when you don't know tricks like that take on a magical meaning)
Thank you all, @jmsavoyat is it possible to have the file?
I tried to use this function, but without success...
Edit: Ah, I get it, it must be made of sheet metal...
Yes, you must indeed be in sheet metal mode and in the library for the part files to be identified as a sheet metal function, the folder must be declared as "Shape Tools".
Otherwise the tutorial of @Bart "Tool-of-form" to which Benoit refers is very good.
Here is the piece.
Afterwards, for a standard form of Sw, yes Jm is right, everything is premade in Sw
Then yes, it has to be sheet metal work!
@ PL
best answer is not the one designated
I put you - 1 for the gesture
And all his questions will be like that to pick up 40 points every !!!
Pathetic but it doesn't surprise me on your part!
Clementine, reacts!!
