It is not a sheet metal part, so it is impossible to make sheet metal. I don't think the sheet metal module is capable of handling a simple helical surface by the way.
Must:
- draw it on the surface and thicken the surface
or
-draw the part in 3D on one side and then refine the part by removing material until 'shifting the surface', using a shell function, removing material with an offset surface..
The result will be the 3D of the desired part. Then it's up to the stamper to deal with it (it's his job after all...)
There is no real solution!
The solution would be by stamping
But solid does not have the stamping module to make this part
THANK YOU
gt22
December 6, 2016, 9:37am
58
This is obsolutely false
You just have to create your own tool and then you can create your stamping
so I put -1 on the answer that you validated as best
See this tutorial among others
https://www.youtube.com/watch?v=SHNIm0X6Txk
GT22
I had already tried this solution but on my puck it doesn't work
but if you succeed, I'm a taker...
gt22
December 6, 2016, 1:41pm
60
give me the dimensions of your washer STP
and I look at it right away
There is no problem, there are only solutions!! +1 shape tool, just create the shape you want and save it in .sldftp format.
Yes it exists, look at page 5 I had put you an image of the stamping function, there is the tool by transparing and the stamped plate.
gt22
December 6, 2016, 5:58pm
65
Here is your form tool so you can handle the problem now
via the tutorial posted on one of my previous answers
attached file SW 2012
david_heyraud_rondelle_spirale_forme.sldprt
Thank you GT22
I created a split washer, inserted and then positioned your tool, but when I validate the stamping is not done and my shaft is red..?
gt22
December 7, 2016, 9:52am
67
Have you registered my part as a stamped shape tool part
Watch the video posted previously
or this
http://www.lynkoa.com/tutos/3d/outil-de-forme
yes I saved it as a shape tool
no pb for the isertion in my part
gt22
December 7, 2016, 10:36am
69
can you show via a screen the defs of the stamping function (creation tree)
the faces taken into account etc
gt22
December 7, 2016, 10:54am
71
you can't insert an image on the com feed it's + simple and smoothable
you need the part but also the settings on the function so open the function and show us it please
