Hello
I have a sheet metal part
I don't understand why the unfolded state is messing up
Attached Exhibit
Thank you
probleme_pehd.sldprt
Hello
Attached Exhibit
Thank you
Hello
Could you please give us screenshots of the creation tree and the room so that we can ALL get an idea of the problem because we don't all have the same version (2016 for me) so we can't all open your file.
Kind regards
Good evening @llemilbeau
I looked at your piece.
The anomaly occurs very early in the creation tree.
In fact, it is your sketches 26 and 28 that are causing a stir. Indeed, you do a beveled material removal that trims the fold with folded edge and that doesn't please SW at all when he wants to unfold again. It is not excluded that you will have the same problem with "sheet metal with folded edges3"
My strictly personal point of view : Your notching is not realistic in relation to the thickness of the sheet. Laser cutting will do it for you, but the folder will curse you for three generations and it will make you shit when folding. I would make all the cuts in the original sheet metal and I would do the two folds last. To be even closer to the reality of the folder and the material, I would make sketched folds instead of "folded edges" which are less suitable for folds of a few degrees. Pay attention to the bend radius. You have the image of the pb attached which will be easier to read.
Kind regards
Hello I found this morning
it's that my "normal material removal" was not checked
I manage to have the unfolded
Thank you for your help;)
Hello
Is the flattening done well on all the folds?
Kind regards
Now it is enough to close the question
naming the best answer
