Hello
How to activate the toobox because having changed machine I reinstalled SW.
But I no longer have access to the toolbox how to reinstall it.
Thank you
Hello
Thank you
Hello Zozo,
do you have a PRO license activated?
No, I'm in the premium version and I had this function in the V 2017.
I need to make a cam and if there is another way than with the tools box I am taker.
Otherwise I make a spline for the tests but blah blah!
If you have the Premium then you have the right to the toolbox,
restarts the installer and verifies that it is checked, also checks these paths.
Thank you Pierre S
Stupid question how to restart the installer program.
Thank you
SUBSIDIARY QUESTION Should we use the Toolbox Cam tool or can we constrain a continuous surface without it being a cam?
I very rarely use this function and it's a hassle every time.
To restart the program, it depends if you're on W7 or W10.
under W7: open an explorer, "uninstall/modify a program;
Under W10: Control Panel/Programs and Features;
Choose the right version of SW.
Hello
Check that Toolbox is checked.
may the force be with you.
Good evening friends
I realized while helping a colleague on the forum about simulation module, that I simply didn't forget to check toolbox in Tools==>Complements==> toolbox and also to check "load it at startup".
It's the remark of OBI ONE "check toolbox" which reconnected my memory
If zozo starts to zozotter and starts to burn his neurons, it's off to a bad start.
Thank you for your help anyway :-)
