Hello
Following a hard drive crack I can no longer transfer the SW 2012 license bought in 2012 to CADWARE Toulouse, a reseller that no longer exists, how to do it please, thank you
Hello
I already had this problem; You have to call Dassault to disable it on this disk to make it available again
The acquisition of Cadware having been made by Visiativ, I think he will take over on this point.
I have a doubt if there is no active maintenance (SW2012 is starting to date a bit
ha dear, you're on a collector's item there!!
It's going to make you a generational leap when you find a newer version ![]()
Especially the number of files that will jump when changing versions.
We have already done a SW2009 → SW2014 transition, some files did not appreciate the conversion at all (surface which shattered for example)
