Hello
How can a 3D polyline be transformed into a 2D polyline on Autocad?
Thank you in advance for your answers
Hello
Hello
There is an option for this, in English, it is:
Ribbon
Modify tab
Design panel
Convert 3D To 2D Polylines
Menu
Grading menu
Polyline Utilities
Command Line
Convert3dPolys
See the other two tabs here:
http://docs.autodesk.com/CIVIL/2010/ENU/AutoCAD%20Civil%202010%20User%20Documentation/index.html?url=WSfacf1429558a55de1d677851071c252c77-71a4.htm,topicNumber=d0e97388
and in French what does it look like to follow,
I tested the "Convert3dPolys" command as shown but it marks me unknown command
And with a front dash? _Convert3dPolys
Because English commands can be launched in AutoCAD thanks to this dash
same answer unknown command
In fact, a priori this command exists in AutoCAD CIVIL 3D, but not standard AutoCAD...
So there is a LISP program available here but the one for message #5 is not found, the one for message #6 should work:
http://cadxp.com/topic/25683-convertir-polyligne-3d-en-polyligne-2d/page__p__139911__hl__24255__fromsearch__1#entry139911
Otherwise, ask that he repost the program they talk about in message 5...
Hello
Otherwise, there is the "FLATTEN" command of the "Express Tools" which flattens any object according to the current view (so put yourself on the plan view).
It remains a 3D polyline but all vertices have their Z=0.
Then, if you absolutely want a 2D polyline, you explode the 3D polyline and you run the "_PEDIT" command to recreate the polyline using the "join" option. If you have 50 to do, I don't think it's worth it.
A+
Hello
You break down your 3D polyline
You open the properties window
You select the whole of your now broken down polyline.
In the properties window the "Z-start" and "Z-end" are "Varied", you have to set them to 0.
Then, all that remains is to join the lines to make a polyline (2D).
There you go
Have a nice day!
Thank you for your answers
