Hello
The trihedron command used to move components in an assembly is not always present in the context menu and I don't understand if its access is dependent on very particular conditions or if it is a bug.
Thank you for your help
and good design
Hello
and good design
Hello. The trihedron appears in assemblies when you right-click on a part that is not fixed. technically and by default the first part of an assembly is fixed so you can't move it with the trihedron you have to release it, you click right and normally in the list you have "free"
You can also see which parts are fixed in your assembly by looking in the creation tree on the fixed parts you have an f in parentheses.
Here's hoping that this answers your question, if your room is free and you don't have the trihedron by right-clicking on it then it may be a bug but personally it never happened to me
You can customize your context menu too (at the very bottom of the menu)
Personally, I have a different menu between the display fan and the design tree
Thank you for your quick answers, but unfortunately they don't solve my problem. Even on a freed and unconstrained part, the trihedron doesn't always appear in the context menu but sometimes it does. it is incomprehensible.
same problem on 2012 and 2017 :-(
Hello, to move with the trihedron ==>right-click on the piece to be moved and then choose "move with the trihedron"
may the force be with you.
If you right-click and expand your menu with the double down arrow, is "move with trihedron" checked?
Hello
Stupid question, but is the part you select for movement really on the first level in your father assembly? If this is not the case and the sub-assembly in which this part is located is fixed or totally constrained, then it is normal that the displacement function is not available.
Kind regards
@ Pascal: my trihedron is still active in my menu but doesn't appear tjrs.
@d.Roger: I did the test with fix/release, on parts without any constraints and I still didn't understand why it is sometimes accessible and others not.
Hello
Do you select your part to move in the construction tree or in the display window?
Can you put a screenshot of your tree?
Kind regards
Isn't it a graphics card problem by Hassard?
give us your pc config if possible and SW
Hello d.roger
I've tried both ways, the result is the same and my assembly is only one level.
Hello gt22
This problem doesn't seem to look like a graphical problem but......
My config is:
Microsoft Windows 7 Professional operating system
Version 6.1.7601 Service Pack 1 Build 7601
Additional Information Not Available
Publisher Microsoft Corporation
STA009 Computer
Manufacturer FUJITSU
Model No. : CELSIUS W530
x64-based PC type
Intel (R) Xeon(R) CPU E3-1271 v3 processor @ 3.60GHz, 3601 MHz, 4 core(s), 8 logical processor(s)
BIOS Version/Date FUJITSU // American Megatrends Inc. V4.6.5.4 R1.34.0 for D3227-A1x, 01/08/2015
SMBIOS version 2.7
Windows directory C:\Windows
System directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Regional option France
Hardware Abstraction Layer Version = "6.1.7601.17514"
with an Nvidia quadro K2200:
Name : DameWare Development Mirror Driver 64-bit
Plug and Play Device ID ROOT\DISPLAY\0000
Board Type Not available, DameWare Development 64 compatible
Description of the DameWare Development Mirror Driver 64-bit Board
RAM on the board Not available
Installed drivers Not available
Driver version 1.1.0.0
INF file oem57.inf (DwMirror section)
Color Plans Not Available
Color Table Entries 4294967296
Resolution 1920 x 1080 x 60 Hz
Bits/pixel 32
Driver c:\windows\system32\drivers\damewaremini.sys (1.1.0.0, 5.50 KB (5,632 bytes), 3/14/2008 4:00 PM)
Name : NVIDIA Quadro K2200
PCI Plug-and-Play Device ID\VEN_10DE&DEV_13BA&SUBSYS_109710DE&REV_A2\4&10883CE5&0&0008
Card Type Quadro K2200, NVIDIA Compatible
Description of the NVIDIA Quadro K2200 card
On-board RAM (1,048,576 ) bytes
Installed Drivers nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver version 9.18.13.4752
INF file oem43.inf (section Section148)
Color Table Entries Not Available
Resolution Not available
Bits/pixel Not available
Memory address 0xF6000000-0xF6FFFFFF
Memory address 0xE0000000-0xEFFFFFFF
Memory address 0xF0000000-0xF1FFFFFF
I/O port 0x0000E000-0x0000E07F
IRQ Channel IRQ 4294967292
I/O port 0x000003B0-0x000003BB
I/O port 0x000003C0-0x000003DF
Memory address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\nvlddmkm.sys (9.18.13.4752, 9.81 MB (10,284,872 bytes), 05/05/2015 08:35)
The problem occurs much less often as I get better at sld.
So I think it was a problem constraints that had to be present but that I didn't see.
Thank you all for your help.
