Hello
I am looking to sort a list of welded parts according to at least 2 criteria
By type of profiles and then by length in each profile
I don't see how to do it, is it even possible?
Kind regards
Hubert
Hello
Kind regards
Hubert
Hello
A priori we can't do two sorts in the same table, but I will make one table per profile by deleting the profile(s) not concerned in each table.
The project will gain in clarity, especially for the person who will carry out the flows
Hello
There is a way to sort the complete list manually, in the "Properties of the welded parts list" menu: right click on one of the items in the welded parts list.
Then on the "Welded Parts Table" tab, you will give the desired order to your welded parts. Be careful, I believe that changes are not taken into account by simple update, you have to delete the table in the MEP to insert a new one.
Good evening
Try the 2 walkthroughs to see which one is the most practical. The lack of automatic updating in Carseb's solution annoys me a little. It's crazy that at Dassault they didn't think of that!!
A+
Hubert
