Type of lines autocad 2019
Hello
I can't change the type of lines. Only the "continuous" and "zigzag" types work.
What must I do?
Kind regards
Hello, although I don't use Autocad  you should probably be able to change them in your window to define layers / lines / texts.
yes but it doesn't work
Thank you
Before you can use a line type, you need to load it: autodesk help
