Hello
Using SolidWorks 2017 and PDM Standard, I'm in the process of fine-tuning the workflow configuration.
Can you tell me if it's possible to allow a transition only to a user who isn't the last one to edit the file?
For example "$Auteur is not equal to %Username%", or something like that?
Does "Prohibit sequential state changes" also work with the initial state?
Thank you in advance!!
              Okay, so it's the "Prohibit sequential state changes" option that allows me to do what I want. In the meantime, I was able to test on a different trunk than the production one. Moreover, the help is quite clear on this subject:
Users cannot perform two sequential state transitions on a single file.
As an example, you can use this option to prevent users from approving their own files.
