Is it possible to put the views in the animation bar to create a video?
Can you explain, I didn't understand :-)
It goes back a long way from memory, just drag and drop them.
No, I created my views in "view mode", I think I can drag them into video mode but it doesn't take them!
Can we convert them?
No, I created my views in "view mode", I thought I could drag them into "video mode" but it doesn't take them! As soon as I switch to video mode and click on a view, it goes back to view mode!
Can they be converted?
Views created in view view are stored in the left banner.
Even without creating an animation they are already playable (morphing).
In the player or the exe there are before the video buttons, the camera buttons, the views are played in order with a delay between each.
If you drag the views into the bottom timeline to create an animation, it works, can you make a screenshot of composing?
Edit: if you click on a view in the right banner during the animation you actually go back to view mode. (normal).
Indeed the views are played in order but I have views for a paper doc, so I don't want to use them all. I'd really like to do the animation.
Here is the screenshot. When I try to drag a view on the timeline I have the forbidden icon!
The timeline is at 0 tries to move it and drag a view.
I used this method very little once for a burst. (can create an index)
I'm trying to see if I still have access to 3DVIAComposer.
All the parts of the assembly must be visible during the video, I had parts unchecked! If it helps.
