Is it possible to have several appearances within the same function?
Let me explain a little more. I have a material removal function that is composed of several holes and I would like to put a different color on each hole, is this possible?
Thank you.
Cdt
Fred
If you ask the question it's because you see an interest in the result, but frankly I doubt that this is possible in automatic, especially in the same function.
When you say each hole is one color per diameter of the hole?
You can assign an appearance on several levels:
- body (the whole body)
– function (all faces generated by the function)
— surface (only selected surfaces).
For what you want to do, it's going to be at surface level. So in manual selection hole by hole...
Good luck...
            See also this topic for color assignment by hole type via macro:
https://forum.mycad.visiativ.com/t/couleur-predefinie-pour-un-type-de-percage/105717
Yes, with the drilling wizard, but not with the material removal function, where @a_eriaud is right.
            Thank you all.
Fred
