ba send it to me the image at home it doesn't work.
I'll send you my images as soon as my network is repaired.
Sorry!
@bart: After the 2nd image, did you have it rebuilt? And if you redevelop the BOM display, the bubble info remains?
@Bart
Can you do the test by putting 2 parts in the assembly and putting the PWR on the part and not the assembly. This is the only difference that persists with the image of @jsourd!
Hi all!
Here is the last test!!
I did it with an assembly, I didn't even need to rebuild, everything follows automatically
No problem!
I attach the photo.
@jsourd: can you send your example in zip (assembly of 2 cubes + MEP)?
@bart will be able to try your model...
I took back your files, (I hadn't seen that there was an answer...)
Indeed, there is a small problem on your mep.
So I recreated it with my background.
Here's what I get
So I advise you to redo your mep by removing the old one.
Sometimes Solidworks bugs a little and when restarting the mep, it passes. What for? I don't know, but it happens.
In any case, with your plays, I succeeded. And I haven't touched anything about your config.
Good luck in any case.
And don't hesitate to come back!
If it works for @bart, the problem is probably with your drawing or BOM template !
@bart, can you send me your drawing that I'm trying on my side to see if it's my MEP or my name that poses pb...
Ok thank you Bart, indeed it doesn't work.
I did the manip again, you will find attached the 3 images of the setting up of the bubble:
Capture 1 balloon with article number: the balloon symbol appears in the name.
Capture 2 Changing the bubbles to custom property: the bubble symbol appears in the name.
Capture 3 Blueprint update: The bubble symbol disappears.
(image in 3 messages).
So a priori no solution for this point. tampi we close the subject.
Thank you in any case for looking at my pb.
See you soon for new problems I hope easier to solve...; -)
If the Lynkoa community has not been enough, and in particular the service of @bart, call the hotline...
