Hello
I can't turn my solidworks file (assembly) into a step. I think the file is too large. Do you have a solution?
Thank you.
Hello
Thank you.
Hello
Have you tried to change the version of the Step. ( .step ap214 or .step ap203) when registering?
Otherwise try unchecking settings in the export options:
Remove anything that can weigh down unnecessarily (screws and other small parts)
Azrod> I've tried both versions but there's no change.
For the settings, what will it change during the export?
Hello
I think you should first try to make it a part and then make it a step. This is to send to someone who has SolidWorks??? Otherwise you can also try Parasolid the 4th type from the top...
sbadenis > I can't remove the screws and small parts (I need absolutely all the parts in the step file).
ac cobra> I know that all software can open the steps, is it the same for the parasolid?
Hello
It's happened to us before. I recommend saving in SolidWorks as a part, keeping all the bodies, and then from this part to save as a STEP.
Parasolid is a classic, there are also IGES and SAT which are common.
How many parts in the assembly (there is a "statistics" function in SW)?
stefbeno > I have 136 components (so not huge in my opinion) and the file is 16,351 KB in size.
Maybe I'm doing it wrong when recording. But I also noticed that my solidworks crashes when I try to open steps that are too bulky (from the top solid software).
.PL > Unfortunately my software crashes when recording in pieces keeping all the bodies...
There is quite a bit of software that opens it...
After a try to record it in parasolid, the software crashed after a second of reflection...
Hello
If it's to send to a customer, there is still the solution of executable edrawing.
It allows the client to open the file without having eDrawing.
It's often a heavy file, but you just have to compress it with winrar.
Bart> the file is intended for our subcontractors. We switched to solidworks for a short time, we had no problems when we were on top solid to do the steps.
Can you attach the native file?
To see if we get to the same size of step files at the beginning?
What version of SolidWorks is it? SP5 for 2015 and earlier, or SP3 for 2016?
The latest SP solves a lot of bugs!
have you all your parts solved in your assembly
especially if it crashes after an attempt to record in parasolid
you must have a problem somewhere
how many sub-assemblies do you have
how did you create this assembly
.PL >We are in the SP3 solidworks 2016 verse.
gt22 > All my parts are resolved. In my assemblies, there are 2 sub-assemblies. On the other hand, I have a motherboard that is a surface part (after opening the step, it generated an assembly but we only wanted one part so as not to manage 2000 parts and we didn't find any other solution than to make it a surface part). Could the problem come from there?
See this link Opening Large Assemblies in Solidworks
http://www.mycadblog.fr/ouverture-de-gros-assemblages-dans-solidworks/
How long does it take you to open your complete assembly in solidworks
See this great tutorial for the management of large assemblies
https://www.youtube.com/watch?v=2Ai7iJNYQMI
From memory, the surface is mega heavy.
Try to remove the motherboard, if it works, re-register it in volume parts.
After several tries, I finally managed to record in step. On the other hand, after opening it, to check that all the parts were present. The motherboard does not appear.
Bart> How do you record a surface piece in volume?
