Bjr team,
It's not a topic but just a rant.
I'm really tired of this window, the hours wasted are unbearable.
Hello OBI_WAN,
Ditto I think it's for everyone that this problem is recurring, untimely and really unbearable, ...
Good luck to you, may the force be with you!! ...
AR.
Agree and "NOT HAPPY" too...
Especially since their "Automatic Save" system is so time-consuming that we don't use it either.
I imagine that you said to yourself: "Well I'll do this last operation, then I save ... and PAF!
I sympathize.
Legend has it that with the 3Dexperience, this window would have died!
Legends are beautiful!
In the meantime, courage to you.
How did you guess ![]()
we started looking at the 3D experience but we gave up.
too nebulous and really very expensive.
The famous automatic save system that crashes SW when it saves? Clearly it's often better without .
@froussel or else that makes you lag your PC for 5 minutes when you shouldn't, and sometimes crash in addition for the same price. ![]()
Like everyone else deactivated for a long time...
hooo damn I have the same one at home ![]()
Ditto it's been a long time since I disabled the auto save (since 2009 in fact ^^)
Sometimes it crashes when you delete a so-called smart part, or indeed just when you want to save, it's like, if SW was reading minds... strange^^ where is it the fact that we have an 8th sense that tells you that, it would be time to save, close SW and then re-open... But the problem with the 8th sense is that it is a train behind unlike the 6th.
Team not happy ON.
Unfortunately I see that we all have the same problem, it's almost reassuring
What makes me laugh is that we all have the same feeling at the moment when it crashes this feeling of "but how did he guess that I wanted to save right after"
I wanted to push the thing by adding Mario's music (when you lose) at the moment when the pop up with the green line appears
I'm going to make an improvement request to add that
, at least it would be funny ![]()
Solution found!! ...
=> just missing the sound
With a small 8-bit game over sound
I love taking +1up to lose it in the process. ![]()
Above all, don't switch to the 3D exp, we have it and we've regretted it since the 1st day. Basically, Dassault is tinkering to connect 2 things that are not originally intended to work together. As a result, it crashes all the time, not to mention the backup problems. SW is a great product, SW + 3Dexp is to make you disgusted. The only way to avoid having a problem with the 3Dexp is not to use it.
If you need a PDM, PDM Works does the job perfectly, but it's very expensive. Except that they would like to stop it apparently in favor of the 3Dexp.
I see that Visiativ is advertising for SolidWorks PDM. I don't know if it's the same thing.
Thank you @pierre.edouard even if I don't want to come there at all, it seems that the next licenses sold whether we like it or not will be equipped with it.
In any case, thank you for the feedback, even if that's not really how we were sold it in the subject dedicated to it! I'm almost surprised... ![]()
The link to the subject if you ever want to testify about your experience:
Hello;
[Off-Topic Limit Mode: ON]
Why am I not surprised by this type of feedback, sorry, from 3DExperience...
We would need a screenshot of their "Cloud" crashing... it's for the collection of @OBI_WAN
... and mine too.
[Off-Topic Limit Mode: OFF]
Kind regards.
FYI: we have PDM Enterprise.
It works generally well even in multi-site (USA/France) but it's necessarily long when you work on an 8000km basis. On the other hand, we had a dedicated internet line.
It is possible that your problems are related to the quality of your internet connection (but the coding of the thing with the feet is also highly likely...).
I have never been tempted by these miracle and "disruptive" solutions as long as the bugs of everyday life remain (trying 3D parametric curves works but only unnecessary complications). And then these things that go who knows where; I prefer the local that works even when the weather is bad outside and the wires are dancing on their poles. I thought I was a dusty old man. You reassure me.
Hello
guess what just happened to me???
