Create configurations with text?
Is it possible to create configurations with text?
let me explain, I have a large series of parts to make in DL and each time the difference between each part is a number or a letter, usually I do this with a 2D software, but today I can't read the font with my 2D software, on the other hand with SW I can do this without problem, but now I would like to save as much time as possible to create my number plates!
I thought about making families of parts or config, but finally what I have to modify between each part is the sketch of the text and not a function!
Anyone may have a tip? I have about 300 plates to make, otherwise I'll export the text from SW to my 2D and do some tracing/cutting/welding as they say around my house :rofl:
Look at the answer in these 2 topics:
Thank you for your very quick :ok_hand: feedback, I had tried to find a similar topic before posting, but I must not have put the right keywords :eyes:
I reassure you, the search for the site is not great or even zero at ch...
I went through a search engine as usual to search for a topic. with the keywords "Mycad text configuration"
Thank you :upside_down_face:
Indeed with that I should be able to find a trick by separating my texts, I'm going away for the weekend but from Monday I'll tell you if it's ok for me :ok_hand:
