Gantt chart
Hello,
Who would have an excel gantt chart template to do tracking and industrial management for machining parts please?
Hello,
Today, many gantt templates are available directly from excel.
However, here is a relatively advanced in-house version in terms of formula and display:
Gantt Excel.xlsx (71.5 KB)
I also suggest you to study the GanttProject Freeware solution: GanttProject: Free Project Management App
@Lenny_Kr , what does this have to do with 3DEXPERIENCE?
Hello Silver_Surfer,
Thanks for the Gantt.
AR.
@Le_Bidule
Maybe here the answer
3DEXPERIENCE Project Planner XPP Role (visiativ.com)
hello @Lenny_Kr , if you are open to an alternative, I invite you to try Tracking (https://www.suivi.work) an industrial project monitoring tool with a native Gantt view, designed for design and machining contexts. It also allows you to directly visualize 3D, which can be useful to associate your parts with their progress. The use is free and your feedback would be invaluable to us to improve the use of Tracking in the industrial context.
Hello;
Could you tell us more about:
There's not much about it on your site.
Which visualizer do you use (Edrawing, Visiativ's, other?) Can you show the Assemblies? The parts? Both? Which file formats are playable by your App?
It seems that you are a partner of Visiativ (Visiativ Agora in any case), what interweaving tools are possible?
Hello @Maclane ,
The 3D viewer integrated into Tracking is now based on a lightweight web viewer (based on Three.js), which allows us to guarantee a quick opening and a good fluidity of use directly in the browser.
Its objective is to offer a simple handling for control and presentation uses: zoom / rotation / movement, screenshot...
We currently support the visualization of single parts and assemblies converted to GLB (web-optimized format).
We have clearly identified the possibilities of integration with the Visiativ 3D viewer.
Use cases were explored around the conversion and direct visualization of native CAD files
At this stage, these integrations are not yet offered in Follow-up, but we remain attentive to customer needs on this subject and more generally to possible synergies in the Visiativ Agora ecosystem.
As Claude indicated, you can try the tool for free and submit your ideas in the forum open to users by going to the following address: An ultra-custom control tower to manage your projects | Follow-up
Do not hesitate to share your use cases, it will help us to prioritize the evolutions.
For this type of follow-up, I would start with a fairly simple Excel Gantt with at least: part reference, operation, machine, manager, start date, end date, expected duration, progress in % and status.
Ideally, you should also add a column for delays or blockages to quickly see which operations are likely to delay the rest of production. For machining, this quickly becomes more useful than a purely graphic Gantt.
