Gas threading and 3D printing
Hi all
Currently under SW2021,
I am working on a project where I need to 3D print parts with threads for gas type screw fittings (e.g. G1" or G1/8 threads...). So far, the standard metric threads feature in SolidWorks works very well for 3D printing, a slight rework is required but nothing anomalous with the printing accuracy.
Is it possible to retrieve a parameterization or configure SolidWorks to generate gas threads suitable for 3D printing? If so, what is the best method or steps to follow to achieve a functional and accurate thread on 3D printed parts?
Thank you in advance for your feedback and advice!
Go see in the toolbox you should find what you're looking for... But not sure
https://forum.mycad.visiativ.com/t/outil-filetage/103190
Bonjour;
Le problème de Solidworks est qu’il ne gère pas l’inclinaison sur les filet Gaz Coniques…
Je pense que pour l’impression 3D le moins risqué est de créer sois-même des profils d’esquisses avec extrusion ou enlèvement de matières hélicoïdaux (avec ou sans angle sur l’hélice guide).
L’aide de Solidworks propose ceci:
https://help.solidworks.com/2019/French/SolidWorks/sldworks/r_thread_guidelines.htm?verRedirect=1
Video disponible chez Jevelin:
Video chez GoEngeneer / Grabcad.
Est quelques exemples sont disponibles sur GrabCad: (Non testés)
nota : +1 :+1: pour:
… c’est suffisamment rare de ne pas à avoir à « réclamer » la version utilisée pour le souligner… :smiley:
:rofl: It allowed me to check that the version was not the right one
It's 2021 :upside_down_face:
Well -1 :+1: (or +1 :-1:, I get lost in my accounts...)… :smiley:
Another short illustrative video for extrusion following a helix (or coil):
note: @Sylk should be able to tell you more, he's both in 3D printing and in coils these days.
@DoubleL should be able to help you too, he's our 2024 Golden Tech winner after all.
Hello @SebJo
What 3D printing technology is it for?
One method would be to start from this table to create a profile, choosing the most suitable step (higher) than the degree of precision of the 3D printer:
Personally, I use the thread function. I already printed an M14 cap and it screwed very well
{E8272B70-537A-4A02-AA0C-4700A4C6F57A}
But I don't think it's possible to make gas threads, otherwise you have to reopen the GDI and start drawing the profile
Hi all
We print with a FormLabs Form 3
We had to make several attempts at printing, we assume that the printing regularity was not at its best, not enough support? Not enough tolerance?
But the method is there, GDI+ adapt a SW metric profile to do it at our convenience
Thank you for your feedback :pray:
Have a nice day
