Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swExportPDFData As SldWorks.ExportPdfData
Dim boolstatus As Boolean
Dim Filename As String
Dim lErrors As Long
Dim lWarnings As Long
Dim strSheetName() As String
Dim varSheetName As Variant
Dim swDraw As SldWorks.DrawingDoc
Dim vSheetNames As Variant
Dim Part As Object
Dim File As String
Sub main()
Set Part = swApp.ActiveDoc
' ajout controle du bon fichier
If Part Is Nothing Then
MsgBox "Aucun fichier n'est actuellement ouvert."
Exit Sub ' If no model is currently loaded, then exit
End If
' Determine the document type. If the document is a drawing, then send a message to the user.
If (Part.GetType <> 3) Then '1Part 2Assembly 3Document
MsgBox "Cette macro ne s'applique que sur une mise en plan"
Exit Sub
End If
File = Part.GetPathName
If File = "" Then
MsgBox "Cette macro necessite que le fichier soit préalablement enregistré"
Exit Sub
End If
Dim Filepath As String
Filepath = Left(File, InStrRev(File, "\"))
Filename = Mid(File, Len(Filepath) + 1, Len(File) - (7 + Len(Filepath)))
Set swModelDocExt = Part.Extension
Set swExportPDFData = swApp.GetExportFileData(1)
Set swDraw = Part
vSheetNames = swDraw.GetSheetNames
Dim i As Long
Dim j As Long
j = 0
ReDim strSheetName(UBound(vSheetNames))
For i = 0 To UBound(vSheetNames)
If InStr(vSheetNames(i), "Plan") <> 0 Then
strSheetName(j) = vSheetNames(i)
j = j + 1
End If
Next
varSheetName = strSheetName
If swExportPDFData Is Nothing Then MsgBox "Nothing"
boolstatus = swExportPDFData.SetSheets(swExportData_ExportSpecifiedSheets, varSheetName)
swExportPDFData.ViewPdfAfterSaving = True
boolstatus = swModelDocExt.SaveAs(Filepath & "\" & Filename & ".PDF", 0, 0, swExportPDFData, lErrors, lWarnings)
'DWG
boolstatus = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfVersion, swDxfFormat_e.swDxfFormat_R12)
boolstatus = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, swDxfMultisheet_e.swDxfSeparateSheets)
boolstatus = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfVersion, 0)
boolstatus = swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, 1)
longstatus = Part.SaveAs3(Filepath & "\" & Filename & ".DWG", 0, 0)
Kill Filepath & "\" & Format(i, String(2, "0")) & "_" & Filename & ".DWG"
End If
Next
Essaie le d'abord sur une copie de plan on ne sait jamais et dit moi si cela correspond
Je voit ce qui plante lors de mes test il n'arrivait pas a renomer si le fichier existait donc je le suprimait mais si il n'existe pas il n'arrive pas a le suprimer je rajout un controle de fichier
