I would like to recover the mass properties of certain bodies on a multi-body part with different material (mass, area, volume) in order to put them on my plane.
To do this, I select the bodies in question. So I have the mass, volume and area. But I can't get these properties back for my plan.
By going through smartproperties, you can do it, but it's room by room.
What I want is the mass of a set of multi-body pieces. I select the bodies in question in the mass property, I have the weight, volume, and area. So far, no worries. Then, in terms of my drawing, I have to manually annotate the properties of all the bodies in question. I can't copy/paste.
It is a 3D file in .sldprt format. I draw a lot in multi-body. For example, a gate, with a steel frame and wood infill. For a DDP painting concerning the frame, I need the weight and the surface to be painted of the bodies in question. Each time I fill in these elements manually.
The best practice for this type of construction would be an assembly with a multibody part for the scrap metal and one or more parts for the wood inserts, screws, handles, etc. This greatly simplifies the drawing, a plan for the boiler factory, an assembly plan (not necessarily the same person) And especially for your weights the possibility of drawing the overall weight of the boilermaking part and the surfaces.
if it is the data of the 1st plan that are in the following MEP because I think you make several tabs; If so, click on one of the tabs, then properties, then uncheck the box identical to the specific layer... see image and there it should work
