Hello Twathle,
Back for my last message, here is my tutorial for information =>https://mycad.visiativ.com/contenu/ajout-la-masse-pour-chaque-corps-dun-mécanosoudé-dans-sa-liste-de-piéces-soudées?tuto
And here is also the model of the " Welded Parts List", make good use of it!! OL. ![]()
EssaiListePiécesSoudée.zip (1.9 KB)
Hello
What is unfortunate is that you have to fill in the mass property for each item in the welded parts list. That said, it works well.
Another solution is to enter the ground property for each profile... ![]()
Hello Le_Bidule,
And yes indeed you have to inform.
It's possible with a macro, but I don't know how to do it ... @+.
AR.
Hello;
Here is a small macro to automatically add the " Mass " property on all mechanically welded elements (Welded Parts List):
=> If specific materials are assigned to certain elements they will be taken into account, otherwise the density of the Global material is kept...
Option Explicit
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim FileName As String
Sub main()
On Error Resume Next
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
MsgBox "Pas de fichier Pièce Solidworks actif..."
End
End If
If swModel.GetType <> 1 Then
End
End If
'swModel.Save
FileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
Set swFeat = swModel.FirstFeature
Do While Not swFeat Is Nothing
If swFeat.GetTypeName() = "CutListFolder" Then
Set swCustPropMgr = swFeat.CustomPropertyManager
swCustPropMgr.Add3 "Masse", swCustomInfoText, Chr(34) & "SW-Mass@@@" & swFeat.Name & "@" & FileName & Chr(34) & " Kg", 1
End If
Set swFeat = swFeat.GetNextFeature
Loop
Note: it is possible to customize the line.
swCustPropMgr.Add3 " Mass ", swCustomInfoText, Chr(34) & " SW-Mass@@@ " & swFeat.Name & " @ " & FileName & Chr(34) & " Kg", 1
=> " Mass " is the Name of the property to be created
=> & " Kg " (optional text)
Macro for use exclusively on Solidworks Parts files.
Kind regards.
@Cyril.f I temporarily suspended your " Best Answer " to bring up this discussion... But I keep in mind the value of your answer. ![]()
I don't chase the best answers ![]()
a big thank you to you, this helps me a lot
